NoopyKat1
Aug 13, 2013Aspirant
ReadyNAS DuoV1 - Post 4.1.12 Upgrade no SSH, Frontview, etc.
I have ready through most of the posts and after seeing that none had all of the problems I have, decided to ask for help. Sunday I decided to upgrade my ReadyNAS Duo V1 from 4.1.10 to 4.1.12. I ha...
azurar01
Aug 31, 2013Aspirant
Hello, I too decided to upgrade my ReadyNAS from 4.1.10 to 4.1.12. I had no add-ons installed all appear to go well, until the install did not appear to finish. I.e. the Blue LED was still flashing 6 hours later. I switched off the NAS, and then restarted it the next morning. The share was active, but there was no access to Frontview. I rebooted the NAS and since then it has been in a 'booting ...' status.
Since I don't have SSH loaded I tried a reset in the hope that a reinstall of firmware would improve matters. No Change.
Has anyone found a way to move the install on ?
Or is there a way I can roll back the firmware to the earlier version ?
Sid.
Sid.
