NoopyKat1
Aug 13, 2013Aspirant
ReadyNAS DuoV1 - Post 4.1.12 Upgrade no SSH, Frontview, etc.
I have ready through most of the posts and after seeing that none had all of the problems I have, decided to ask for help. Sunday I decided to upgrade my ReadyNAS Duo V1 from 4.1.10 to 4.1.12. I ha...
climbernl
Sep 05, 2013Aspirant
Same story,
Upgraded from 4.1.10 to 4.1.12 (PHP add on), that seemed to work oké. System reboot and I couldn't connect tot Frontview anymore. Share's are still reachable, so functionality is there, just not WebGui access. I have no ssh access.
Tried to downgrade using a USB stick with 4.1.10 by shutting down the ReadyNas (by holding the power button for a few seconds) and rebooting it with the USB stick inserted, using the described procedure of holding the power button for 20 sec (hdd lights flash for the 4th time). The NAS than seems to do something by flashing the power button and sometimes the HDD lights, also the fan runs at full speed, but even after an hour, this still goes one, while the procedure says after a few minutes the downgrade should be finished and you can hear this by the fan powering down.
After a manual shutdown (by pulling the plug, since the power button is unresponsive) and a reboot, RAIDar (v 4.3.8. Windows) still claims version 4.1.12 is installed and I am still not able to reache the NAS through the WebGUI (Frontview).
Please advise on an alternative (without having to Fabric reset the enitire NAS)
