NoopyKat1
Aug 13, 2013Aspirant
ReadyNAS DuoV1 - Post 4.1.12 Upgrade no SSH, Frontview, etc.
I have ready through most of the posts and after seeing that none had all of the problems I have, decided to ask for help. Sunday I decided to upgrade my ReadyNAS Duo V1 from 4.1.10 to 4.1.12. I ha...
climbernl
Sep 05, 2013Aspirant
Yesss,, finally after a couple of reboots I was able to gain access to the NAS through SSH (Putty SSH port 22, user "root").
First tried to restart the Frontview service:
# /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -k restart
but no luck so looked at the log
# tail /var/log/frontview/error.log
And found indeed the issue with PHP. In the directory: # cd /etc/frontview/apache/addons
I renamed every PHP addon to "old"
Then a reboot (# reboot) and another attemp tp restart frontview. And Voila: running.
With many thanks to the info about the right commands:
https://www.readynas.com/forum/viewtopic.php?f=65&t=71880&start=15
