NoopyKat1
Aug 13, 2013Aspirant
ReadyNAS DuoV1 - Post 4.1.12 Upgrade no SSH, Frontview, etc.
I have ready through most of the posts and after seeing that none had all of the problems I have, decided to ask for help. Sunday I decided to upgrade my ReadyNAS Duo V1 from 4.1.10 to 4.1.12. I ha...
NWFisher
Sep 12, 2013Aspirant
mgdm,
Thank you. HTTPS connection fixed per your advice! As before, it works fine with IE10. Now the email notification about 5 weeks ago from ReadyNAS Xtras regarding a PHP5 bug fix with firmware 4.1.12 makes sense. I was busy at the time so it was ignored then while doing admin on the NV+ this morning I noticed new firmware so upgraded. I'll install the bug fixed PHP5 later, other work you know.
Thanks too for your really fast (and accurate) assistance and to your team for the PHP5 email notification!
NWFisher
NWFisher
