dindsy
May 16, 2013Aspirant
ReadyNAS hangs about 1 minute after booting
Hi there, i have a ReadyNAS NV+. it's years old and has been working fine apart from a FAN failure or two. I haven't changed anything on the device or my PC, routers or any connections. Well, not del...
May 16, 2013Guru - Experienced User
I am wondering about a full OS partition.
If you have enough time try to delete all logs (backup and system). DON'T download them; if the OS partition is full, then you could totally lock up the box.
Sometimes an OS reinstall will help also.
You could try a support request via support.netgear.com - cleaning out the OS partition is straightforward.
