dindsy
May 16, 2013Aspirant
ReadyNAS hangs about 1 minute after booting
Hi there, i have a ReadyNAS NV+. it's years old and has been working fine apart from a FAN failure or two. I haven't changed anything on the device or my PC, routers or any connections. Well, not del...
May 17, 2013Guru - Experienced User
The OS partition is separate from the data volume - deleting the logs wouldn't help your data free space (and deleting the movies wouldn't help the OS partition).
However, it is important to maintain reasonable free space on both.
Do you have SSH installed? It's the only way to easily tell how full the OS partition is.
