dindsy
May 16, 2013Aspirant
ReadyNAS hangs about 1 minute after booting
Hi there, i have a ReadyNAS NV+. it's years old and has been working fine apart from a FAN failure or two. I haven't changed anything on the device or my PC, routers or any connections. Well, not del...
May 17, 2013Guru - Experienced User
log in as root, using your admin password
then type "df" That will list all the mounted file systems, giving their size (in 1 KB blocks), used blocks, free blocks, and % use.
The OS partition for the NV+ is ~2GB (~2 000 000 blocks). It should be listed first, if I recall correctly it is /dev/hdc1 on my system.
