dindsy
May 16, 2013Aspirant
ReadyNAS hangs about 1 minute after booting
Hi there, i have a ReadyNAS NV+. it's years old and has been working fine apart from a FAN failure or two. I haven't changed anything on the device or my PC, routers or any connections. Well, not del...
mdgm-ntgr
May 18, 2013NETGEAR Employee Retired
Do note that your NV+ (v1) does not support disks with higher capacity than 2TB. If you want to use 3TB disks you will need a new NAS.
