NemoNL
Feb 18, 2020Aspirant
Readynas interrupting internet connection on VDSL
Dear Community, recently we moved houses and are now using VDSL for our internet connection. Previously we had Cable and before that I was working with the same Readynas on Glassfibre internet as...
Feb 18, 2020Guru - Experienced User
NemoNL wrote:
Does anyone know what could be causing this and how to resolve this?
If the ReadyNAS MTU is set to 1500, try lowering it to 1492.
- NemoNLFeb 19, 2020Aspirant
StephenB wrote:
NemoNL wrote:Does anyone know what could be causing this and how to resolve this?
That seemed to have helped a lot, thanks StephenB!. The connection is more stable, but still is disconnected every so often. I'm seeing a few series of disconnections last night and some now this morning. But at least it is coming back by itself.
Major improvement, but still something is not 100% ok. But at least this would be workable.
- StephenBFeb 19, 2020Guru - Experienced User
1492 is the usual value for PPPoE, but it might need to be a bit lower still.
You can determine the value using ping - in a Windows PC you run CMD (command prompt) and then enter
ping -l 1464 -f 8.8.8.8
If you see a message that says
Packet needs to be fragmented but DF set.
then lower the 1464 value until you find the largest value that doesn't give that error. Then add 28 to the final value, and set the MTU to that size.
Another possibility is that something else on your network might be using the default 1500. It is possible to set the MTU on PCs (both MacOS and Windows). But unfortunately I don't think you can manually set the MTU for Android (without rooting the phone) or iOS. The MTU can be signaled via DHCP, so if your devices are using DHCP it might not need to be manually set.
- NemoNLFeb 24, 2020Aspirant
When I ping with 1464, it comes through in one piece. No error messages. So it seems that MTU set to 1492 should work.
And I spoke to soon as well, it did work for a while, even though there were a few short interuptions, but after a full day it went back to it's old state, meaning constant disconnects.
The moment I physically disconnect the NAS, they stop and the connection goes stable again. Or if I disallow the NAS access to the WAN, it also remains stable. And this is 100% reproducable. Which means it has to be the Readynas somehow.
Is it possible the ReadyNas is trying to make it's own PPPoE connection? That was one suggestion I got from AVM, but I do not know how to check this.
