tdawgy
Sep 07, 2013Aspirant
ReadyNAS NV+ dead drive no backup please help!
Current state: With disks 1,2,3,4 in I get a booting... Bad Disk Found With disks 2,3,4 in it will boot but Frontview is never accessible. Also says that 1/1GB are free (all 4 drives are 1TB). R...
vandermerwe
Sep 07, 2013Master
Drive 4 has probably failed, do you know what the smart stats were when the errors were reported?
Can you boot with 1,2,3?
When did you buy the unit? Warranty still valid? If so contact support and don't do anything else.
Cloning the disks is an option - you would need to clone1,2,3 and try to boot with the cloned disks.
