tdawgy
Sep 07, 2013Aspirant
ReadyNAS NV+ dead drive no backup please help!
Current state: With disks 1,2,3,4 in I get a booting... Bad Disk Found With disks 2,3,4 in it will boot but Frontview is never accessible. Also says that 1/1GB are free (all 4 drives are 1TB). R...
mdgm-ntgr
Sep 11, 2013NETGEAR Employee Retired
It may be as simple as powering off the system adding the clone and then booting the NAS. Whatever you do, don't add the disk while the NAS is on as disks added while the NAS is on are wiped.
I would wait though to see what support suggests first.
It's possible that some of your data may not be recoverable (some may be corrupt) but hopefully most of it will be.
Data recovery places you try should be familiar with Linux and software RAID. If they are not don't use them. In future please backup your data regularly. It is much cheaper than using data recovery services and can help save irreplaceable data.
tdawgy wrote:
I work late and long hours, these pictures are my window into time lost with my kids/wife. If I lose all of these I'll be ruined. If this doesn't work, I'll send them off to one of those "clean room" data recovery places. Hopefully it doesn't come to that, but if it does, any suggestions?
