GeorgeYYZ
Mar 30, 2018Aspirant
ReadyNAS NV+ disc replacement failure using identical disk type
My ReadyNAS NV+ is equipped with 4 identical 2 TB drives. Seagate Model ST2000DM001. I am running XRAID. Was receiving notices of increasing bad sectors, in increasing numbers on Drive 4. Purchased a...
- Sep 06, 2018
GeorgeYYZ wrote:
The Ultra 4 is currently running under X-RAID2. I assume that this is equivalent to X-RAID...
Yes. On the Sparc NAS (NV+, etc) they called it X-RAID, then with Ultra/Pro they rebranded it to X-RAID2. With OS-6 they went back to XRAID.
In all cases it is "expandible raid", the details on expansion vary, depending on which platform you have.
GeorgeYYZ wrote:
but I will revise my upgrade plans to 4x4TB, since that is a suitable match for my Synology DS918+ .
It'd be sensible to match their capacities. You can then use one to back up the other (I use my older-but still working ReadyNAS as backups).
Mar 30, 2018Guru - Experienced User
GeorgeYYZ wrote:
Purchased a 3 TB Seagate drive online. Model ST3000DM008.
If your NAS runs 4.1.x firmware, then the max drive size is 2 TB. A 3 TB drive will appear much smaller and can't be added to the array.
Overall, Seagate DM drives don't have a good track record in RAID arrays. I'd suggest either a 2 TB WDC Red or a 2 TB Seagate Ironwolf. Both are NAS-purposed drives. I use a WD20EFRX in my own Duo v1.
- GeorgeYYZMar 30, 2018Aspirant
Thanks for this information. My NAS is running 4.1.16 firmware, as you suspected. Are there later firmware versions for the NV+ that allow greater capacity than 2 TB per drive? That would also be welcome news to me.
I should say that I've had a good experience with these 4 Seagate DM drives until very recently, with over 5 years of use in 4 different locations. Nevertheless, I have just gambled on your advice and ordered a WD20EFRX online. I will report back with results after it has been installed.
In te meantime, do you have any advice on "drive preparation" when it arrives, or should I just put it in "hot" and pray for sync to begin? I have been unable to locate any advice on drive prep on the Netgear site, or in the Community pages. Thanks again for your help!
- StephenBMar 30, 2018Guru - Experienced User
Unfortunately not. The hardware design goes back to ~2007 or so, and simply wasn't designed to handle >2 TB drives .
The 3 TB version has a rather poor reputation ( https://www.backblaze.com/blog/3tb-hard-drive-failure/ ) and I've quite a few issues with that particular model posted here. In general, I recommend either NAS-purposed or enterprise-class drives for RAID. Years ago, desktop-class drives made sense, but NAS purposed drives are similar in price, and have the right features for RAID.
The disk is formatted by the NAS when you insert it, so no prep is needed. You should probably test it with Western Digital's lifeguard utility in a PC before you use it though. For Seagates, you'd use Seatools.
I recommend hot-insertion of the new drive (with the NAS running).
- GeorgeYYZApr 15, 2018Aspirant
Hello Stephen,
It has been about two weeks since our last communication. Since then I ordered the drive you recommended (WD20EFRX), installed it, and tried to get my NAS back to redundant status. Long story short, it didn't work, and the new drive cannot be initialized using Windows and gets a WD Lifeguard "Fail". Here is a log of my attempts:
Boot without Disk 4. NAS runs OK but not redundant
Insert Disk 4 HOT
Disk 4 activity light and Main activity light both flashing intermittently.
(A good sign? I don't know.)
LCD says "Disk 4 inserted"
Cannot ping, no RAIDar or Frontview access.
Wait ....... 4 ......... days
No result. Tired of waiting. Power button does not respond.
Perform "Improper shutdown" (pull plug).
Boot without Disk 4. Runs OK but not redundant
Insert Disk 4 HOT again.
LCD says "Disk 4 sync"
Email says "RAID sync started on volume C."
Disk 4 activity light flashing. Main activity light not flashing (???)
Can ping but no RAIDar or Frontview access.
Wait ....... 6 days, 1 hour, 20 minutes.
No result. Tired of waiting. Power button responded for shutdown.
Still shows IP address and "Disk 4 sync" on LCD, even though power is OFF (???)
Restart with Disk 4 installed.
LCD says "Booting Please Wait ...."
Power light goes from fast to steady flash. Does not boot beyond steady flash.
Power button does not respond for shutdown. Pull plug.Restart with Disk 4 installed.
Pull Disk 4 HOT
Power light goes to slow flash, booting commences.
LCD says "Booting"
Re-insert Disk 4 while "Booting" underway.
Disk 4 activity light and main activity light blinking
Quota Check begins
RAIDar access show Disk 4 with Red X
Quota Check complete
LCD shows IP address, Total/Free space.
Frontview says disk is dead.
Pull Disk 4 HOT.
Lose Frontview connection
Lose IP ping.
LCD says "Kernel panic"
Restart with no Disk 4 installed.
Quota Check begins
RAIDar access shows Disk 4 with Red X
LCD shows IP address, Total/Free space.Boot without Disk 4. NAS runs OK but not redundant
Insert Disk 4 HOT
LCD says "Disk 4 inserted"LCD clears, then says "Kernel panic"
End of tests. End of log.
I hope these notes are helpful to someone.
