factotvm
Oct 19, 2019Aspirant
ReadyNAS NV+ no longer staying connected... Catalina?
I have recently upgraded to macOS Catalina, and since about then I am unable to use Time Machine on my ReadyNAS NV+. It begins the process, but will eventually lose connection with the error: "The ba...
Oct 19, 2019Guru - Experienced User
factotvm wrote:
One bit of information that makes me think that this is a coincidence with the Catalina upgrade is that I am also unable to connect easily to the web-based aministration tool. It does connect sometimes, but not consistently.
Maybe try downloading the log zip file, and look there for errors. I also suggest looking at the disk health (either via disk_smart.log or look at the SMART stats in the web ui).
- factotvmOct 27, 2019Aspirant
The SMART stats appear to be alright. There are a good deal many errors in the log. The most troubling I see is
kernel: After TLER: status = 0x50, error=0xd600
And
kernel: hdc: drive_cmd: error=0x04 { DriveStatusError }
- StephenBOct 28, 2019Guru - Experienced User
And
I suggest testing the disks with vendor tools in a PC. Use Lifeguard for Western Digital; Seatools for Seagate.
