factotvm
Oct 19, 2019Aspirant
ReadyNAS NV+ no longer staying connected... Catalina?
I have recently upgraded to macOS Catalina, and since about then I am unable to use Time Machine on my ReadyNAS NV+. It begins the process, but will eventually lose connection with the error: "The ba...
Marc_V
Oct 20, 2019NETGEAR Employee Retired
Welcome to the Community!
I'm not really sure if this might be the caused of it. https://www.macworld.com/article/3445481/can-t-find-your-time-machine-backup-after-upgrading-to-catalina-look-for-a-backupbundle.html
It says there that upgrading to Catalina causes the .sparsebundle extension change to .backupbundle. If you can try accessing your TimeMachine backup and see if it did changed then changing it back to sparsebundle extension might get it detected. You can follow the guide on locating the backup here.
Or restricting Time Machine to use SMB might be another cause? Hopefully we can get more information on this. Please send in the logs so we can check if there's any issue as well with the NAS regarding access to it.
Regards
- factotvmOct 27, 2019Aspirant
The backup starts... it just doesn't complete. I do see the .backupbundle has been created and touched.
