Slim1
Feb 15, 2018Aspirant
ReadyNAS NV+ (RND4000 v3) Won't Boot - Stuck at "Resyncing Volume"
ReadyNAS NV+ is stuck "Resyncing Volume". Now I am desperate to reclaim my data! I was getting error messages about the USB backup on the RAID system not working but was unable to get the logs di...
bedlam1
Feb 15, 2018Prodigy
Factory Reset will wipe all your data, the ten minute pause is just a period to cancel it proceding, nothing more
Feb 15, 2018Guru - Experienced User
Actually the purpose of the pause is to give you a chance to change the default RAID mode from XRAID to FlexRAID via RAIDar. Current NAS don't need that, but OS 4 and OS 5 systems do.
But there is no option to preserve data, so don't use the factory reset boot menu choice unless you are prepared to lose it.
