a904044
Mar 03, 2016Aspirant
ReadyNAS NV+ stuck "Booting..."
Yesterday my ReadyNAS powered itself off. After a power up I see with Raidar that it completes the file system check, but then never becomes operational. It disappears from Raidar and the LCD display...
- Mar 06, 2016
The system wouldn't boot due to a failed attempt to download the logs (there were some very large log files). The problem is now fixed.
a904044
Mar 04, 2016Aspirant
OK, thanks. So apart from running the memory test some more, is there anything else I can do to diagnose the problem ? Is there any way, for instance to get at logs or diagnostic information on the NAS that can tell me what's going on ?
mdgm-ntgr
Mar 06, 2016NETGEAR Employee Retired
- meyMar 24, 2016Aspirant
I have this same problem. My NV+ has been "booting.." for about 2 weeks. The initial error came after a power outage and has not finished booting since. Raidar will not locate the device in this "booting..." state.
How were you able to access the large log files and fix the problem. This solution is missing from the string. Thank you for your help.
- a904044Mar 25, 2016Aspirant
My problem was fixed by mdgm remotely accessing my readynas
