DeanTierney
Mar 29, 2016Aspirant
ReadyNAS NV+ v2 - "no data volume" since upgrading disks
Hi all, We have attempted to increase the storage on our NV+ v2 by replacing the four existing 1TB drives with 3TB drives (confirmed the new drives are compatible). The first 2 were replaced succ...
- Mar 30, 2016
One of your disks has 45 ATA errors.
The RAID array the data volume sits on isn't starting.
This looks like a data recovery situation to me. You could contact support and enquire about the costs of purchasing data recovery.
I notice that you had filled in the Contact Us form but not yet taken the steps to turn it into a case.
Mar 30, 2016Guru - Experienced User
Also, what firmware is running on the unit?
JennC
Mar 30, 2016NETGEAR Employee Retired
Hello deanTierney,
Welcome to the community!
You mentioned: The console was also not accessible (via the browser interface) so I needed to do a hard reset to bring it back up
What do you mean by hard reset, how exactly did you do it?
Do you have full backup of the data?
- DeanTierneyMar 30, 2016Aspirant
The firmware version is 5.3.11
JennC, I pulled out the mains power to restart the box.
No backup, unfortunately.
Thank you all, by the way, for your help.
- mdgm-ntgrMar 30, 2016NETGEAR Employee Retired
Are you able to send in the logs (see the Sending Logs link in my sig)?
Logs sent as requested. Thank you
