rus44
Aug 17, 2016Follower
Readynas nv+ v2 - problem with apt-get
Hi, I am trying to run an apt-get update on my readynas and it's failing with..... apt-get update Hit http://security.debian.org squeeze/updates Release.gpg Ign http://security.debian.org/ squeeze...
mdgm-ntgr
Aug 17, 2016NETGEAR Employee Retired
If you set a static I.P. did you remember to specify the DNS server addresses? You could try adding Google DNS (8.8.8.8)
Installing packages from newer Debian distributions would likely break things. It is stuck on squeeze.
