DeltaTee
Oct 15, 2013Aspirant
ReadyNAS NV Will Not Boot With Four Disks
My ReadyNAS NV with 4.1.10 will not boot with all four disks installed: (1) Power loss caused reboot. ReadyNAS would not boot. Pulled disk 4, then system booted. Added new disk 4, everything OK ...
mdgm-ntgr
Oct 16, 2013NETGEAR Employee Retired
Have you noticed a burnt smell?
Can you power down and remove the PSU and look to see if it is damaged?: http://www.readynas.com/kb/faq/hardware/how_do_i_replace_the_stock_power_supply_on_the_readynas_nv
Is your serial number in this range?: http://www.readynas.com/forum/viewtopic.php?p=54911
