Slegnor
Aug 24, 2016Follower
ReadyNAS NV+ working fine but front panel LED's don't work at all
Just got a ReadyNAS NV+ with 8tb storage for very cheap, it all works in terms of the discs/RAID etc but the front panel lights dont work other than the blue one behind the power button. The backup ...
Aug 24, 2016Guru - Experienced User
The lights should work, it is not a known issue with 4.1.15. AFAIK they are not user-replacable.
Your NAS is quite old (discontinued in 2011). It's limited to 2 TB disks, and it's transfer speeds are much slower than current units (it is limited by the sparc CPU). Mine is also still in service, I use it as a backup NAS.
