jbandes
Aug 17, 2016Aspirant
ReadyNAS OS 6 and Home Shares with Backupexec 15
I am using Backupexec 15 and when I connect using the Linux Agent I can see all of the shares except the HOME shares are missing. I tried to login as Admin but it fails. I login as my user name which...
Aug 17, 2016Guru - Experienced User
jbandes wrote:
I am using Backupexec 15 and when I connect using the Linux Agent I can see all of the shares except the HOME shares are missing. I tried to login as Admin but it fails. I login as my user name which has administrative rights and I can see all of the shares except the HOME shares so I cant back them up. Does anyone know how I can fix this.
I'm not familiar with backupexec, so a little background might help. Is the Linux Agent installed on the NAS? If not, how is it accessing the shares? SMB or NFS???
Normally the NAS won't show you the home folder - it will only show you your own home subfolder (same as your user name). You can see home (as a folder in the full data volume) if you access the NAS shares using the NAS admin credentials. For instance, in a windows PC this will mount the full data volume - by default named data - (including .apps and home):
net use * /delete
net use t: \\nasipaddress/data /user:admin nasadminpassword
There is an old post from someone who was able to mount home via NFS - that is here: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-t-Use-NFS-to-Access-Home-Shares/m-p/955507/highlight/true#M84643
If that fails, one workaround is to back up home locally (using a scheduled NAS backup job) to a restricted share, and then use backupexec to back up the copy.
