ScottChapman
Nov 11, 2014Apprentice
ReadyNAS Pro 2 cron.daily not working?
So, I put a backup script into cron.daily. But doesn't appear to be running. Is there something I need to do to make it work?
dsm1212
If your script has a .sh extension remove the extension.
If you are logged in as root you can run-parts manually with the -v switch.
steve
steve
