chrismo2001
Oct 19, 2016Aspirant
ReadyNAS Pro 4 — ERR: Could not properly extract
Im haveing that same issue and need help from someone to restore my firmware. I did a factory restore and now its stuck in "booting." when I try to reinstall OS it tells me "err: can not extract" I c...
- Oct 20, 2016
Rebooting. Your NAS should now be not only fixed but also running the latest firmware RAIDiator-x86 4.2.30.
mdgm-ntgr
Oct 19, 2016NETGEAR Employee Retired
It does support that. Have you tried pressing the backup job button for longer than 15 seconds?
You press and hold the backup button
Press the power button briefly to turn the NAS on
Continue to hold the backup button till after seeing a message on the display on the front of the NAS that indicates that it is booting from USB.
chrismo2001
I have. Im on the 3rd usb. I hold it down and it just gets stuck on a blinking course on the LCD. Doesn't do anything. I have formatted it properly and followed all the instructions.
- mdgm-ntgrOct 19, 2016NETGEAR Employee Retired
O.K. I've sent you a PM with an alternative suggestion.
- mdgm-ntgrOct 20, 2016NETGEAR Employee Retired
- chrismo2001Oct 20, 2016Aspirant
WOW!!! Thank you so much! I figued you needed to telnet into it to fix whatever was going on.
Again! Thank you so much!!!!! :D
