der_ger's avatar
der_ger
Guide
Nov 25, 2017
ReadyNAS Pro 4 [X-RAID2] looses connection to LAN repeatedly after update to RAIDiator 4.2.31
My Ready NAS Pro 4 looses accessability from the local LAN on transfer of larger amounts of data. A factory reset did not solve the problem. Restoring data from an USB-Disk works.
My ReadyNAS Pro 4 ist connected to my LAN via a Netgear WNR 3500L just used as a switch, the router and DNS-server is a Maipu-Modem. This configuration worked quite well for 2 years. About four or five month ago my NAS startet to loose connection to the LAN in an increasing frequency. The only way to reconnect the NAS is to manually shut it down and restart it. Update to firmware RAIDiator 4.2.31 did not help, but made the situation even worse. The ReadyNAS stays connected for even days when there is only small data traffic. Copying larger amounts of data (like an amount > 2 GB pictures from a camera storage card) will work for a while (some minutes) and then suddenly the NAS will hide, so that the connection is lost and data transfer is interrupted. Not even the admin-account of the NAS can be reached or connected then unless the NAS is manually shut down (power off) and restarted.
There are no further apps installed or used on the NAS.
I've already posted this topic once, but factory reset did not help. Can anyone help me? I'm just a basic user with no great experience in setting up networks or things like that. So please explain on a very basic level for me.
  • StephenB's avatar
    The next time it happens, can you try disconnecting the ethernet cable from the NAS, and then reconnecting it?  You should then see the IP address show up again on the NAS LCD display.  Then try accessing the NAS again (without rebooting).
    • der_ger's avatar
      der_ger
      Guide
      Hello,
      I tried it, but this does not work. When the NAS gets inaccessible the IP-Adress remains displayed, only when disconnecting the LAN-cable it says, that there is no LAN connected. After dis- and reconnecting the IP-Adress ist shown again.
      A fixed IP4-adress is assigned to the NAS by the router by using the MAC-adress of the NAS. The same IP4-adress is filled in as a value in the NAS setup menue.
      Only powering the NAS off and switching it on again makes the NAS accessible again.
      • StephenB's avatar
        Can you confirmed that you did a factory reset (destroying your data), and that didn't help?  Or did you actually do an OS reinstall (which does not destroy your data)?
        Also did you try the second NIC port on the Pro?
ProSupport for Business
