der_ger
Nov 25, 2017Guide
ReadyNAS Pro 4 [X-RAID2] looses connection to LAN repeatedly after update to RAIDiator 4.2.31
My Ready NAS Pro 4 looses accessability from the local LAN on transfer of larger amounts of data. A factory reset did not solve the problem. Restoring data from an USB-Disk works. My ReadyNAS Pro 4 ...
Nov 27, 2017Guru - Experienced User
Thx, I wanted to make sure I didn't send you in circles. The NIC ports often fail together, but it is worth trying. There are some issues that only show up on one port (connector problems for instance).
der_ger wrote:
So how to reinstall the OS by the way?
The reinstall procedure is page 21-22 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
der_ger
Nov 28, 2017Guide
StephenB wrote:The reinstall procedure is page 21-22 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
I will try this. I did the update via update file (so I downloaded RAIDiator 4.2.31 and saved it as a file), but i fear that this file is defective and so reinstalling the OS like instructed on page 21-22 from the NAS might not help. How can I make the NAS use a new OS-File?
