der_ger
Sep 18, 2017Guide
ReadyNAS Pro 4 [X-RAID2] looses connection to LAN repeatedly maby cause update to RAIDiator 4.2.31
My ReadyNAS Pro 4 ist connected to my LAN via a Netgear WNR 3500L just used as a switch, the router and DNS-server is a Maipu-Modem. This configuration worked quite well for 2 years. About two or three month ago my NAS startet to loose connection to the LAN in an increasing frequency. The only way to reconnect the NAS is to manually shut it down and restart it. Update to firmware RAIDiator 4.2.31 did not help, but made the situation even worse. The ReadyNAS now only stays connected for a few minutes before it hides itself again. Data transfer especially writing data seems to accelerate the disconnection. Can anyone help me? I'm just a basic user with no great experience in setting up networks or things like that. So please explain on a very basic level for me.
der_ger wrote:
For SSH I will check as soon as I'm back home, but as there is no web-access activated I guess SSH is not enabled.With OS 4.2 you'd have needed to install an add-on to enable ssh.
Based on your symptoms, I suspect that your OS partition is getting full. This is a 4 GB partition on the hard drives that you normally can't access. The NAS boots from it, and if it fills one symptom is that you will start losing connections. The firmware update might have contributed also, since the firmware update process does create temporary files on the OS partition (that perhaps weren't deleted).
Usually the OS fullness issue is also provoked by add-ons (including ReadyDLNA). Though that isn't your situation, I still think that we need to rule out OS fullness.
Overall, you have a choice to make. One option is to contact Netgear paid support (my.netgear.com), asking for per-incident support. They can easily fix OS fullness, and if there is something different going on, they can isolate quickly (remotely).
Another option is for you to try to fix it yourself. That would require use of Linux shell commands (via ssh). If you aren't familiar with linux commands already, then this probably isn't a good option for you.
Either way, it would be prudent to back up the data on your NAS. There is some risk of data loss.
Do you have any add-ons installed on the NAS?
Do you use ReadyDLNA?
Is SSH enabled?
- der_gerGuide
StephenB wrote:Do you have any add-ons installed on the NAS? --> No
Do you use ReadyDLNA? --> No
Is SSH enabled? --> No
The NAS is simply used as a web-Storage, not even individual shares are activated. There is no remote access to the NAS from outside the LAN activated. For SSH I will check as soon as I'm back home, but as there is no web-access activated I guess SSH is not enabled.
Thx
