swetarkus
Oct 11, 2018Aspirant
ReadyNas Pro 6 - rebuild doesn't start
Here's an old one; got a Readynas pro 6 with 6 x 3 TB drives. Beeing working for ages and running fw 4.2.27. As it's been working for ages, I've forgotten most tips and tricks. Case now - 1 driv...
Oct 12, 2018Guru - Experienced User
The most likely explanation is that new drive isn't working. Test it in a Windows PC using Seatools. You can connect it with a USB adapter or dock if that is needed.
- swetarkusOct 12, 2018Aspirant
Thanks....but,, as I wrote - tested with 2 brand new, unopened, Seagate drives!
Both actually the same as I've already got, only 1 step later in revision but otherwise identical.- StephenBOct 12, 2018Guru - Experienced User
Both actually the same as I've already got, only 1 step later in revision but otherwise identical.Sorry, I missed the "another extra" phrase in your first post. That makes it less likely that it's the replacement drives being DOA.
Another possibility is that something is wrong in the NAS chassis. So perhaps the next step is to test the original drive with Seatools and confirm that it has actually failed.
The resync should be completing in less than a day.
