ninjasniper85_
Mar 02, 2023Aspirant
ReadyNAS Pro 6 general protection fault: 0000 [#2] SMP
Issues: ReadyNAS keep freeze when trying access the local IP it doesn't show the login so i have to manual hold the button to reset it What is use for: Storage Data for IP Cameras Raid 6 6x3TB ...
Mar 02, 2023Guru - Experienced User
Next time see if it responds to ping before you reboot it. I also suggest enabling SSH, as that might respond when the web interface doesn't.
Are the command timeouts increasing?
How full is the OS partition?
ninjasniper85_
How full is the OS partition? Currently 4.70TB Free 6.19TB Every Month i delete last month
SSH is enabled
Are the command timeouts increasing? what do you mean this? THROW: open failed path:/data/Reolink errno:2 (No such file or directory)?
Sys.log in PDF Today 3/3/2023 AUS time
Will see when it happen again
What command do i run when it happen on SSH?
- StephenBMar 02, 2023Guru - Experienced User
No, that's not the OS partition - it's the data volume.
- Download the full log zip file from the logs page.
- Open Volume.log
- Scroll down to the section that starts with === df -h ===
- Look at the line for /dev/md0
You'll see something like this
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1.1G 2.7G 30% / ...Let us know what's in the Use% field.
No, I'm talking about these:
System
- Disk 1 has 5 Command Timeouts
- Disk 2 has 3 Command Timeouts
- Disk 3 has 1 Command Timeouts
- Disk 4 has 2 Command Timeouts
- Disk 5 has 3 Command Timeouts
- Disk 6 has 20 Command Timeouts
All your disks are timing out to some SATA commands. That can be due to a disk problem, or the SATA controller in the NAS. It's hard to say, since a disk can lock up the SATA bus, which will create timeout messages for other disks. It could also potentially be a result of your forced shutdowns.
Whatever the cause, you should be looking in the log zip file to see if there is any evidence these counts are going up.
Logs
- 2023-02-27 18:21:46: general protection fault: 0000 [#2] SMP
- 2023-02-27 18:21:46: RIP [] __fget+0x39/0x65
- 2023-02-27 18:21:34: general protection fault: 0000 [#1] SMP
- 2023-02-27 18:21:34: RIP [] __fget+0x39/0x65
What apps (if any) are tunning on the NAS? Is it possible you are running SickBeard?
- ninjasniper85_Mar 05, 2023Aspirant
Hello StephenB
sorry for late response i send a message back but it didn't go through i send it twice yesterday i been busy i check the NAS it still running usually it work for like 1-5 day then it NASV2842021\Reolink say it can't be found on windows 10.
i will wait and see
getting
also netgear,com is slow but i have good internet in Australia don't know why is it doing that
Correct the highlighted errors and try again.
- ninjasniper85_Mar 07, 2023Aspirant
Sorry but THIS website is making me piss off i post about 10+ times repost but it keep deleting my messages
