ninjasniper85_
Mar 02, 2023Aspirant
ReadyNAS Pro 6 general protection fault: 0000 [#2] SMP
Issues: ReadyNAS keep freeze when trying access the local IP it doesn't show the login so i have to manual hold the button to reset it What is use for: Storage Data for IP Cameras Raid 6 6x3TB ...
ninjasniper85_
Mar 07, 2023Aspirant
Here is the sys.log
Mar 08, 2023Guru - Experienced User
The Reolink errors are flooding the log.
I am seeing this
Mar 07 07:22:34 NASV2842021 mdadm[2943]: RebuildStarted event detected on md device /dev/md0, component device resync
Mar 07 07:22:34 NASV2842021 mdadm[2943]: NewArray event detected on md device /dev/md1
Mar 07 07:22:34 NASV2842021 mdadm[2943]: NewArray event detected on md device /dev/md127
But nothing after that on either md127 (your data volume) or md0 and md1.
What are you seeing on the volumes and shares pages of the NAS web ui?
- ninjasniper85_Mar 08, 2023Aspirant
The Reolink is flooding the log i think cause i setup a FTP for my 5 POE Camera to send the picture and video in the NAS for storage cause the inbuilt MircoSD card only 128GB and it doesn't hold a month of video only a week.
will that crash/freeze the NAS?
it is sending data to the NAS when motions detect and it will write data
- StephenBMar 09, 2023Guru - Experienced User
It shouldn't (famous last words).
The transfers are failing at the moment though, and creating a lot of clutter in the logs.
- ninjasniper85_Mar 09, 2023Aspirant
ok understand do i have to decrease the write for my IP Camera > NAS?
also
kernel.log
i have access to the folder atm but it stop sending video and frozen up around 4pm
System log in PDF form
i can access the admin page and nas but nothing sending to the nas no error when i am on raidar when i check diagnostics
like you said the transfer are failing
how do i fix it decrease the Max file size (MB) on my camera
2 camera is set for 1024MB
2 camera is set for 100MB
1 camera is set for 50MB
they are all set for Motion Detection
i do have a setting call Transport Mode
honesty it could be this that causing the log to error and the nas to freeze up
