ninjasniper85_
Mar 02, 2023Aspirant
ReadyNAS Pro 6 general protection fault: 0000 [#2] SMP
Issues: ReadyNAS keep freeze when trying access the local IP it doesn't show the login so i have to manual hold the button to reset it What is use for: Storage Data for IP Cameras Raid 6 6x3TB ...
ninjasniper85_
May 06, 2023Aspirant
Ok i swap ram
The last one was in there lasted 14 days Ish+
This one last it 5 hours đ
so one of the ram is faulty and maybe a hardware is faulty for the https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Current/Downgrade-to-RAIDiator-x86-from-ReadyNAS-OS-notsupported/m-p/859412/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExHR0tNSUFRR09BRjc1fDIzMDczNTB8U1VCU0NSSVBUSU9OU3xoSw#M2683
is there a video for this? cause my learning styles is different and i am not studying into networking i have a IT Technology and Telecommunications Technology background this is way out of my zone đ
going switch the ram again
- StephenBMay 06, 2023Guru - Experienced User
Not sure what you are asking for - do you want instructions on downgrading back to 4.2????
- ninjasniper85_May 07, 2023Aspirant
Sandsharksaid
That's a Pro Business Edition (ProBE), then, not a Pro6. Pro6 models are -200's. Same motherboard, different processor. Though, of course, you've updated yours, anyway.
With that BIOS version, I'm surprised your NAS is booting at all. I have always believed that the fastest processor that can be used with that old version of the BIOS is an E6600. I guess I was mistaken that it won't boot with a faster processor, but I do suspect that has a lot to do with your problems.
Frankly, the easiest way to update the bios is to use a spare drive in place of your current drive set to convert the unit back to RAIDiator 4.2.x, then use the Bios update add-on, then revert back to OS6. That was true even before Debian Jessie became unsupported and you could still easily get the necessary tools to manually update using apt."
cause my 10/03/2008 FLAME6-MB V1.6 BIOS is this
well did the Ram testing i don't know if it still hardware issues cause of one the ram last 14+ days and the other last it 5 hours
My thinking process is getting new/second hand ram stick and test them or just updating the bios cause that the longest i seen it run for awhileif they like a instructions on downgrading back to 4.2 video about it would be great
- StephenBMay 07, 2023Guru - Experienced User
Netgear doesn't support OS-6 conversion, so no videos on this topic from them.
However, there is a downgrade image you can manually install, and reboot. After that you need to do a factory default using the boot menu.
See
