JS78
Jan 02, 2017Aspirant
ReadyNAS Pro 6 not rebuilding raid after entering new disk
Drive 6 failed on my setup of my ReadyNAS Pro 6 (on RAIDiator 4.2.30) . Just entered a new drive of the same make and type drive into the slot. My frontview and log files show conflicting informatio...
Jan 02, 2017Guru - Experienced User
Perhaps check the disk status with RAIDar as well.
I think I'd give it some time to complete the rebuild (which hopefully is happening) before pulling the drive/rebooting again. Then see if the disk status becomes consistent.
JS78
Here's what RAIDar says. However you had a similar case on the forum a while ago, cannot find the post anymore and that did not work either. Because it seems from the log file the process just stops. What process do I need to look for with PS to see if the system is still rebuilding?
- StephenBJan 02, 2017Guru - Experienced User
Maybe look in mdconfig.log in the log zip
- JS78Jan 02, 2017Aspirant
Sorry not sure what to look for hereby the log file
"Device : /dev/md0
Create Time : 1287671053
Update Time : 1483379549
RAID Level : 1
RAID Capacity : 4194292
Disk Size : 4194292
Chunk Size : 0
Disks : 5
RAID Disks : 5
Active Disks : 5
Working Disks : 5
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
Disk Device RAID Disk Maj/Min Sectors State
4 /dev/sde1 2 8/65 8388608 6 [ Active Sync ]
6 /dev/sdc1 3 8/33 8388608 6 [ Active Sync ]
7 /dev/sda1 4 8/ 1 8388608 6 [ Active Sync ]
8 /dev/sdb1 0 8/17 8388608 6 [ Active Sync ]
9 /dev/sdd1 1 8/49 8388608 6 [ Active Sync ]
Device : /dev/md1
Create Time : 1387892850
Update Time : 1483378161
RAID Level : 6
RAID Capacity : 2096896
Disk Size : 524224
Chunk Size : 65536
Disks : 5
RAID Disks : 6
Active Disks : 5
Working Disks : 5
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
1 /dev/sdc2 1 8/34 1048576 6 [ Active Sync ]
3 /dev/sde2 3 8/66 1048576 6 [ Active Sync ]
5 /dev/sda2 5 8/ 2 1048576 6 [ Active Sync ]
6 /dev/sdb2 0 8/18 1048576 6 [ Active Sync ]
7 /dev/sdd2 2 8/50 1048576 6 [ Active Sync ]
Device : /dev/md2
Update Time : 1483379552
RAID Level : 5
RAID Capacity : 9743966480
Disk Size : 1948793296
Chunk Size : 16384
Disks : 5
RAID Disks : 6
Active Disks : 5
Working Disks : 5
Failed Disks : 0
Spare Disks : 0
State : 0 [ ]
4 /dev/sde5 4 8/69 3897586876 6 [ Active Sync ]
6 /dev/sdc5 2 8/37 3897586876 6 [ Active Sync ]
7 /dev/sda5 0 8/ 5 3897586876 6 [ Active Sync ]
8 /dev/sdb5 1 8/21 3897586876 6 [ Active Sync ]
9 /dev/sdd5 3 8/53 3897586876 6 [ Active Sync ]
Device : /dev/md3
Create Time : 1388515528
Update Time : 1483379550
RAID Level : 5
RAID Capacity : 1953503232
Disk Size : 1953503232
Chunk Size : 65536
Disks : 2
RAID Disks : 2
Active Disks : 2
Working Disks : 2
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
0 /dev/sdb6 0 8/22 3907008903 6 [ Active Sync ]
1 /dev/sdd6 1 8/54 3907008903 6 [ Active Sync ]- StephenBJan 02, 2017Guru - Experienced User
All of the RAID arrays in there have only 5 disks, and RAIDar says you have 6. Plus /dev/md2 is not in a clean state.
Do you have a backup of the data?
