Redlikemethodz
Jul 06, 2020Guide
ReadyNAS Pro 6 Stuck on "ReadyNAS" Logo
I'm having the same exact issue described her but did not see a reply option: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Pro-6-6-6-0-beta-2-T117-turning-on-but-stuck-at-booting...
- Jul 14, 2020
I figured out the issue. Whoever previously owned it had a cable from the front panel pluged into the wrong pins on the motherboard. Problem solved.
Redlikemethodz
Jul 06, 2020Guide
Unfortunately I did connect the 4 pin cpu power connector. I also tried a regular atx PSU. The memory seems to be two 1GB sticks. I've ordered a vga header to get some more info.
Sandshark
Jul 07, 2020Sensei
My quick research showed them to be 2GB. But my main concern was that they are not 4Gb "high density" ones, which do not work, and they are not. The memory from your Ultra6 should also work.
The VGA header is your best approach to finding what's wrong. But if the unit will not complete POST (which is high on the list of problems causing this symptom), figuring out why is just trial and error.
- RedlikemethodzJul 08, 2020GuideUnfortunately no luck. Got my vga header cable today and nothing displays. Mobo must be dead.
- SandsharkJul 09, 2020Sensei
Well, that's a shame. Before you give up, check the power supply and memory connections. Since the memory was removed, maybe you should even check that there is a processor.
- RedlikemethodzJul 09, 2020Guide
Good point. I haven't removed the cpu cooler. thanks!
