Redlikemethodz
Jul 06, 2020Guide
ReadyNAS Pro 6 Stuck on "ReadyNAS" Logo
I'm having the same exact issue described her but did not see a reply option: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Pro-6-6-6-0-beta-2-T117-turning-on-but-stuck-at-booting...
- Jul 14, 2020
I figured out the issue. Whoever previously owned it had a cable from the front panel pluged into the wrong pins on the motherboard. Problem solved.
Redlikemethodz
Jul 09, 2020Guide
Redlikemethodz
Jul 14, 2020Guide
