MCEComputers
Oct 16, 2022Apprentice
Readynas Pro 6 "volumes" screen is blank
I am having the same issue reported in this thread. I have a ReadyNAS Pro6 running 6.10.8. There are four 4tb Lenovo branded Seagate EXOS ST4000NM0035 drives installed. When I log in to the admi...
Oct 17, 2022Guru - Experienced User
There was no solution for the previous post. I am guessing that you never had any data stored on these disks - is that correct?
You could doing a factory reset.
