McRob1
Jan 11, 2016Luminary
ReadyNAS Pro Business Edition Hard Drive Upgrade (2 of 6 Drives still allocated at 2 TB)
I attempted to upgrade my ReadyNAS Pro (Business Edition) NAS from 2TB hard drives to 4 TB hard drives with some success but one issue. The NAS had six 2 TB hard drives installed. I wanted to do...
- Jan 11, 2016
Your OS 4.2 NAS won't expand a volume over the 16 TiB threshold, and it also won't expand a volume more than 8 TiB over its lifetime.
Going from a volume size of 10 TB to 20 TB exceeds both of those growth limits.
The solution is painful - back up the data, do a factory reset with all drives in place, and then restore the data.
If you go down that path, then consider migrating the NAS to run OS 6. That would let you expand the NAS in the future (there are no known expansion limits with OS 6). If you leave it running OS 4.2, then you won't be able to expand beyond 6x4TB w/o another reset.
McRob1
Sure wish I would have known that befor I swapped one drive at a time and then waited for the resync.
That was a pain.
What advantage is there to move to version 6?
Does this version still have no control over fan speed on this unit?
Thanks for the input.
BrianL2
Jan 11, 2016NETGEAR Employee Retired
Hi McRob1,
Aside from what StephenB mentioned, OS 6 system offers high-performance disc operations, unlimited snapshots, and advanced data corruption protection, it also introduced new volume maintenance concepts. With regard to fan control, it is still not supported in OS 6.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
