BumFluff
Oct 18, 2013Aspirant
ReadyNas Pro keeps disappearing off network
I have a ReadyNas Pro. It seems to work fine during the day but then sometime over night, every night for the last three nights, is drops off the network. So in the morning it doesn’t appear as a driv...
Oct 18, 2013Guru - Experienced User
There is more than one possibility - one is that the OS partition might be getting full.
Try deleting the logs (backup and system) and see if that helps. DON'T try to download them to your PC first.
Are you using ReadyDLNA? Any other add-ons?
