joebywan
Sep 17, 2015Aspirant
ReadyNAS Pro restarting
ReadyNAS Pro 6 bay. Lastest firmware as per the update on the admin panel. Radiator 4.2.27 Having an issue where it's restarting sometimes, the logs in the admin panel don't say anything as t...
joebywan
Sep 18, 2015Aspirant
Data's not an issue.
I've not noted times, I just saw it restarted last night, grabbed logs, and that's what I found.
Is there a particular log that would have more information on the cause of the restart? The NAS isn't reporting that it's restarting unexpectedly in radiator, so I'm figuring something is getting it to restart.
mdgm-ntgr
Sep 18, 2015NETGEAR Employee Retired
Is the NAS connected to a UPS or directly to a wall outlet?
Do you have ports forwarded to the NAS?
Can you send in your logs (see the Sending Logs link in my sig)?
When did you start seeing this issue of it restarting randomly?
- joebywanSep 18, 2015Aspirant
No UPS
Plex is only port forwarded. Noone other than us has been using it, as it shows me connected devices & it requires auth.
I think it's been happening for a bit. SO complains fairly regularly that nas was playing up in the evening while she was watching something from it.
Logs sent to email address specified in that link.
- mdgm-ntgrSep 18, 2015NETGEAR Employee Retired
Not sure why it is rebooting.
If you disable the add-ons does it still reboot?- joebywanSep 18, 2015Aspirant
I've disabled the addons, we'll have to see.how it goes.
Could you outline what you looked at to try and see why it restarted in the logs so I know for future reference please?
