SimplySynced
Mar 04, 2024Aspirant
Readynas Pro RNDP6000 upgrade fail.
Yesterday while moving files around I noticed that Netgear said the new 6.10.10 was out. Cool reboot to upgrade and boom won't boot. I turn it off and on it goes into safe mode. I let it sit for a bit...
Mar 04, 2024Guru - Experienced User
SimplySynced wrote:
Good deal, shut it down, reinsert the drives and now and I'm back to sitting at 99%. It has now sat like this for 2 hours or more. Thoughts?
You could try booting using the option to skip the volume check.
- SimplySyncedMar 04, 2024AspirantHow would I skip that? I let it sit over night trynna boot and we're still sitting at 99%. Can I boot the system with the drives pulled and then insert them? Will that corrupt the data?
- SandsharkMar 04, 2024Sensei
You make that selection via the reset button menu at boot time.
No, you cannot boot and then insert the drives. That is a very good way to make data recovery impossible.
So I tried to boot and skip the volume check twice and it gets to about 92% booting and then still just sits there.
