SimplySynced
Mar 04, 2024Aspirant
Readynas Pro RNDP6000 upgrade fail.
Yesterday while moving files around I noticed that Netgear said the new 6.10.10 was out. Cool reboot to upgrade and boom won't boot. I turn it off and on it goes into safe mode. I let it sit for a bit...
SimplySynced
Mar 06, 2024Aspirant
I dont have any of that other stuff setup. The one thing I found interesting though is if I have all the disks pulled, all 6 of them. This thing will boot up into safe mode and get an IP that I can reach. I then get the screen of put in the disk for a volume to be created. Which I did not do but I then shut it down. I then actually shut it off, reseated the drives, ran the os reinstall boot menu option. It showed updating firmware and then it has booted. It shows it is currently syncing but everything is there. I then updated the IP address to the static IP I originally had and then during the applying of it it has stopped responding and nothing on the screen again.
