herbg
May 11, 2014Tutor
ReadyNAS Pro to RN516 Upgrade
I'm about to buy a RN516 with 6 Seagate 4TB 3.5" SATA3 64MB Cache OEM Hard Drive (ST4000VN000) that I will install myself. I currently keep all my media data on a ReadyNAS Pro 6350. I intend to us...
May 11, 2014Guru - Experienced User
Rsync or nfs (over the network) will be quicker than usb because with usb you need to transfer twice.
Certainly if you have a gigabit network that it is the case. Using NFS and then editing the backup to use rsync and rerunning it is a good strategy
