herbg
May 11, 2014Tutor
ReadyNAS Pro to RN516 Upgrade
I'm about to buy a RN516 with 6 Seagate 4TB 3.5" SATA3 64MB Cache OEM Hard Drive (ST4000VN000) that I will install myself. I currently keep all my media data on a ReadyNAS Pro 6350. I intend to us...
May 12, 2014Guru - Experienced User
It is possible, though it requires some attention to security. Using certificates (encrypted rsync over ssl) is what you'd want to to.
Also it probably will require the backup job to be run from the office side, otherwise you will probably have trouble traversing the office firewall.
On the bandwidth side - the amount used depends on how much new or changed data is added to the shares.
