herbg
May 11, 2014Tutor
ReadyNAS Pro to RN516 Upgrade
I'm about to buy a RN516 with 6 Seagate 4TB 3.5" SATA3 64MB Cache OEM Hard Drive (ST4000VN000) that I will install myself. I currently keep all my media data on a ReadyNAS Pro 6350. I intend to us...
May 30, 2014Guru - Experienced User
The first step is to go into services->standard file protocols, and enable NFS (then click apply).
herbg wrote: Hmmm ... dumb question but how do you check if NFS is enabled on the ReadyNAS Pro 6350?
When I check the Shares in FrontView, I only see tabs for CIFS, AFP, HTTP/S, and RSync, and Advanced.
Nothing related to NFS is obvious.
Thanks,
Herb...
