Bernhard_Hartl
May 27, 2013Aspirant
ReadyNas PRO6 hangs when BulkCopy
Hello when I copy a huge amount of data or files (e.g. VMWare Images or photos) to my readynas pro it often hangs and goes on copying this files after a while (about 1Minute delay) - JumboFrames a...
May 28, 2013Guru - Experienced User
Agreed.
chirpa wrote: What's more likely here is now with less data on the volume, you are't hitting the 'bad spot' on Disk 1, so the hang doesn't occur.
From those logs I pasted above, you still have issues on that hardware.
Bernard - did you look at the SMART+ stats for the drives (particularly disk 1)?
