a1000ydStare's avatar
a1000ydStare
Follower
Sep 12, 2017
ReadyNAS-PRO6 power supply failure and warranty
Hi there,
I have a Pro6 with a failed power supply.  I see I registered it and it's still under warranty for hardware but, I can't find anywhere how to begin the RMA process.  I'm okay with sending the unit in or replacing the power supply myself.  Can someone point me to the right place or better yet, Netgear, can you help?  :-)
Thanks
Keith
1 Reply
  • StephenB's avatar
    You use my.netgear.com.  After you log in, click in "my support", then "contact support".  You'll see an option there for "replace my defective netgear product".
ProSupport for Business
