a1000ydStare
Sep 12, 2017Follower
ReadyNAS-PRO6 power supply failure and warranty
Hi there, I have a Pro6 with a failed power supply. I see I registered it and it's still under warranty for hardware but, I can't find anywhere how to begin the RMA process. I'm okay with sendi...
Sep 12, 2017Guru - Experienced User
You use my.netgear.com. After you log in, click in "my support", then "contact support". You'll see an option there for "replace my defective netgear product".
