zenpsx
Aug 16, 2017Follower
Readynas Remote
Hi All, Ok heres my problem, I have a Readynas Duo v2 and the ready remote addon has disappeared. any ideas where i can get the addon ??? I've looked everywhere with no luck, if someone could please ...
Aug 17, 2017Guru - Experienced User
I don't have a v2, but per the documention you enable remote access in the ReadyDrop menus for your NAS (page 41 http://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf ).
zenpsx wrote:
Also anyone know why the digital certificate is blocked in IE11 ???
Because it's self signed. It's easier to click-through than fix. One option is to install firefox, which gives you an easy way to save a security exception.
