nyCecilia
Apr 22, 2020Aspirant
Readynas Remote?
Hi all, Does anyone know if ReadyNas Remote is still workable? I know I've used it in the past but it's been a loooooong time... I'm still using my Pro Pioneer with Raidar 4.2 so Cloud isn't possib...
- Apr 23, 2020
nyCecilia wrote:
... my choir is trying to do a Virtual Choir project ...
FYI, my own choir did something similar last week.
FWIW, another approach is to get a gmail account and use the google drive storage that comes with it. Create a shared folder, and forward the link to the choir members. That doesn't involve the NAS at all, and still allows the choir to upload from their browser.
nyCecilia wrote:
The http option sounds interesting, I'm just not sure I remember how to do it anymore
With OS 4.2, you
- create an upload share (let's call it upload)
- enable http as one of the sharing protocols
- forward port 80 to the NAS in your router.
- get a DDNS name for your router (there are a couple free ddns options out there, including noip.com). For instance nyCecilia.ddns.net
- Install any needed ddns client (or use built-in ddns support if it has it)
Then users browse to http://nyCecilia.ddns.net/upload
A variant is to forward a different external port to port 80 of the NAS (for instance, forward 54321 to port 80). Then choir members browse to http://nyCecilia.ddns.net:54321/upload
As a precaution, I suggest setting a particularly strong admin password for the NAS before you forward the port, and you don't want to leave this access open for longer than you need it.
Apr 22, 2020Guru - Experienced User
It's not available any more.
You could enable http temporarily on a share, and they could use their browser.
- nyCeciliaApr 22, 2020Aspirant
The http option sounds interesting, I'm just not sure I remember how to do it anymore lol I've gotten old the same way my ReadyNas has lol. But thank you for the answer and the suggestion. I'll see if I can find anything in the support section.
- StephenBApr 23, 2020Guru - Experienced User
With OS 4.2, you
