KayZak
Nov 10, 2016Aspirant
ReadyNAS Replicate Job Returning "Connect error code: -51"
Hi All, (Please do not tell me to contact support. They are thoroughly unhelpful.) I recently purchased a second ReadyNAS RN102. Both ReadyNAS RN 102's are running on OS 6.6.0 and are on the ...
Nov 10, 2016Guru - Experienced User
KayZak wrote:
but I'm assuming that means the devices are connected if there isn't that error message?
Probably it does.
You can independently check that the NAS can reach the internet by trying to install an app. Pick something simple (AV plus perhaps), and remove it after it installs.
- StephenBNov 10, 2016Guru - Experienced User
KayZak wrote:
StephenB Both are connected. :)
I suspected that, but thought it was worth checking before you go crazy with more esoteric possibilities.
My backups are all local (other than CrashPlan) so I just use rsync. Replicate is on my list to set up, but likely you'll get this figured out before then.
Hopefully some Netgear folks will chime in with suggestions.
- FramerVNov 12, 2016NETGEAR Employee Retired
Hi KayZak,
Here are some of the basic things to check.
Communication problems between NASes
Errors codes in Replicate portal logs. 50, 51, 122, 300, 501
- Check the Internet connectivity and service connectivity on both sides.
- ReadyNAS OS 6. ReadyNAS Remote should be enabled on both sides.
- For restrictive firewalls and more complex networks, consider setting up port forwarding. (port 6300).
- Remove Replicate user binding and re-add the NASes to the Replicate account. Then, recreate the backups. Use the “resume from…” option to avoid having to send all of the data again.
