GawenT
Jul 15, 2020Aspirant
ReadyNAS Shares keeps disconnecting from network
Hi, I have a client using a ReadyNAS NV+ v2 on site with 4 x 600GB SAS, The NAS is regularly rebooting with no reason, logs show backup issues (known) but no reason for the reboots, Have had the u...
Jul 16, 2020Guru - Experienced User
GawenT wrote:
Checking with the client if 'SMB 1.0/ CIFS Client' access is enabled, though if the clients could always access was always available and this issue has started to occur with a higher frequency than before does this still sound like a simple SMB 1.0 setting is a solution?
If PCs that could access the NAS before cannot access it at all now, then you should check if SMB 1.0 is enabled.
It won't solve the issue with PC dropping their connection to the NAS.
GawenT wrote:
Can you advise if removing the sharing on the NAS and then reinstating this could be a solution?
I don't think that will make any difference.
GawenT wrote:
the only way currently is to soft restart the NAS via the web GUI,
When the problem happens, are all the PCs unable to reach the NAS? Or only some?
GawenT wrote:
when the drives become inaccessible, this occurs every roughly quarter of an hour the only way currently is to soft restart the NAS via the web GUI,
OK. Then we don't know if the problem is in the hardware, or something else.
GawenT
Jul 17, 2020Aspirant
Hi,
Can confirm checked a client computer being affected and SMB1.0 is enabled,
SMB 1.0/CIFS Automatic Removal is also checked, could this be unchecked?
ALL clients are affected simultaneously, none exempt when the issue occurs. Once the NAS is soft restarted for a whil ALL clients can access the shares unitl the issue reoccurs.
NOTE: If I did not say then apologies but if I log on the web GUI i can traverse the data on the shares, and this is quick, not instant but quicker that through Windows File Explorer.
Will the logs give any more clues where the issue lise if this is happeing on the NAS?
- StephenBJul 17, 2020Guru - Experienced User
GawenT wrote:
Will the logs give any more clues where the issue lies if this is happeing on the NAS?
They might - have you submitted them to the mods for analysis?
When this is checked, then if a PC doesn't access the NAS (or another device that uses SMB 1.0) for 15 days, then Windows will disable the client. It would then need to be re-enable via "turn windows features on or off". If the client replaces the NAS with a newer model, then they should just leave the settings alone. But if the NAS ends up remaining in service for a while, then it'd be good to uncheck it.
BTW, there is another issue with this NAS that will need to be worked out soon: it only supports an obsolete version of TLS. Soon that will create issues reaching the web interface. https://community.netgear.com/t5/New-ReadyNAS-Users-General/ReadyNASRND2110-not-supporting-TLS-1-2/m-p/1946376
That does point to an issue on the NAS.
You could try turning SMB off and then on again in the NAS, and see if that is a workaround you can use instead of the reboot. It won't fix the problem, but it would attempt to restart the SMB server in the NAS. It would be faster if it works.
Have you tried re-connecting to a NAS share using the command line on a PC? I suspect it will fail, but probably useful to to confirm.
You'd run CMD, and then enter
net use * /delete /y net use t: \\nas-ip-address\sharename /user:admin nas-admin-password
using a real public sharename, ip address, and admin password of course. Be careful on the typing- particularly spaces and the slash direction.
The first command terminates any open SMB sessions; the second attempts to mount the share as drive letter T.
- GawenTJul 17, 2020AspirantBut if the NAS ends up remaining in service for a while, then it'd be good to uncheck it.- NAS has been in service for years, deselecting this is unlikely to resolve the issue as I am more inclined to this being the NAS than a client issue.BTW, there is another issue with this NAS that will need to be worked out soon.- Strong moves towards the NAS being replaced as it is out of warranty, but need to find the resolution to the issue until that happens.You could try turning SMB off and then on again in the NAS, and see if that is a workaround you can use instead of the reboot.- Will this be per each share or can this (should this) be done globally?Will try your suggestion regarding command line script and report back.Question: Is the latency between file explorer and the speed accessing files/ folders on the web GUI a clue?Can you please advise how to post logs to the mods?
GawenT wrote:
Can you please advise how to post logs to the mods?You upload the full zip file into cloud storage (google drive, onedrive, dropbox, etc).
Then send a PM (Private Message) to the mods ( JohnCM_S and Marc_V ) asking them to take a look. You send a PM using the envelope icon in the upper right of the forum page.
Include a downloadable link to the logs in the PM.
GawenT wrote:
NAS has been in service for years, deselecting this is unlikely to resolve the issue as I am more inclined to this being the NAS than a client issue.I agree it's not your current problem. The automatic removal wouldn't disable network share access on all the PCs at the same time - and if the SMB 1.0 client were disabled on a PC, rebooting the NAS wouldn't restore access.
GawenT wrote:
You could try turning SMB off and then on again in the NAS, and see if that is a workaround you can use instead of the reboot.- Will this be per each share or can this (should this) be done globally?I would do it globally. I'm mot sure exactly how to do that an a v2 NAS (I don't own one, and the documentation doesn't include many screenshots). But in other ReadyNAS there is a way to turn the service off and then back on. You might need to renable it on all the shares after you turn it on.
The idea here is to see to see if the SMB service is hung on the NAS.
Are you comfortable using ssh?
- GawenTJul 22, 2020Aspirant
Hi,
The client has a high performance desktop computer which had SMB1.0/ CIFS Server enabled (now disabled, no clue as to why this had been enabled), this was turned off for the last few days and while off the NAS showed (and continues to show) none of the issues.
I am monitoring the NAS however as there have been no issues as had been happening it seems most likely there as a conflict from this computer.
Thank you for the support, it is appreciated,
