silvercue
May 21, 2013Aspirant
ReadyNas Ultra 2 - Front USB doesn't hold power
Hi, I have been using my ReadyNas Ultra 2 to run scheduled back up jobs to a USB HDD attached to the front USB port. I recently started getting failure emails. On inspection it appears that the...
May 21, 2013Guru - Experienced User
Well, most likely the connector has gotten some damage, or there is a power supply issue.
Either way, if you are the original purchaser and within the 3 year warranty, you should make a support request via support.netgear.com.
